跳转到主内容
Sony Vaio PCG-31311L Motherboard Replacement
你所需要的
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 2 中的图像 1,2 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 3 中的图像 1,1
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 4 中的图像 1,3 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 4 中的图像 2,3 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 5 中的图像 1,3 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 5 中的图像 2,3 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 5 中的图像 3,3
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 7 中的图像 1,2 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 7 中的图像 2,2
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 8 中的图像 1,3 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 8 中的图像 2,3 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 8 中的图像 3,3
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: 步骤 9 中的图像 1,2 Sony Vaio PCG-31311L Motherboard Replacement: 步骤 9 中的图像 2,2
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
结论
另外一个人完成了本指南。
Tyler
于08/24/16注册
45 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 的会员
USFT-LACY-F16S1G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 1,585
