跳转到主内容
Sony Vaio PCG-161L Speakers Replacement
你所需要的
  1. Sony Vaio PCG-161L Speakers Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Speakers Replacement: 步骤 2 中的图像 1,2 Sony Vaio PCG-161L Speakers Replacement: 步骤 2 中的图像 2,2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Speakers Replacement: 步骤 3 中的图像 1,2 Sony Vaio PCG-161L Speakers Replacement: 步骤 3 中的图像 2,2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Speakers Replacement, Speakers: 步骤 4 中的图像 1,1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Speakers Replacement: 步骤 5 中的图像 1,1
    • Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
  6. Sony Vaio PCG-161L Speakers Replacement: 步骤 6 中的图像 1,1
    • Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
  7. Sony Vaio PCG-161L Speakers Replacement: 步骤 7 中的图像 1,1
    • Remove the top casing by lifting up on the plastic exposing the two speakers.
  8. Sony Vaio PCG-161L Speakers Replacement: 步骤 8 中的图像 1,1
    • Remove the two 4 mm screws attaching the broken speaker to the casing.
    • Each speaker has two 4mm screws holding it to the casing. If you are removing both speakers, remove all four screws.
  9. Sony Vaio PCG-161L Speakers Replacement: 步骤 9 中的图像 1,1
    • Disconnect the wire from the board by pulling the wire out of the harness.
    • These harnesses do not have any clips or tabs. Simply pull on the wire and it will come out of the harness.
结论
另外一个人完成了本指南。
Roman Alshehri
于03/08/17注册
407 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 298
