跳转到主内容
Sony Vaio PCG-161L Hard Drive Replacement
你所需要的
  1. Sony Vaio PCG-161L Hard Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 2 中的图像 1,2 Sony Vaio PCG-161L Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio PCG-161L Hard Drive Replacement: 步骤 3 中的图像 2,2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the 6 mm screw on the left side of the battery that holds the casing to the device using a phillips head screwdriver.
  6. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Turn the device upside down and remove the other 6 mm screw holding the casing to the device using a phillips head screwdriver.
  7. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 7 中的图像 1,2 Sony Vaio PCG-161L Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the top casing by lifting up on the plastic.
    • There are no longer any wires connecting the casing to the motherboard. The casing can be fully removed and put to the side.
  8. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 8 中的图像 1,1
    • The ribbon cable covering the hard drive and connecting to the motherboard is held in using zero insertion force (ZIF) connector.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps, then pull the ribbon cable out.
  9. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the four 5 mm screws holding the hard drive to the motherboard.
  10. Sony Vaio PCG-161L Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Remove the ribbon cable connecting the motherboard to the hard drive by pulling the female connector off of the pins attached the hard drive.
结论
另外一个人完成了本指南。
Roman Alshehri
于03/08/17注册
407 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 996
