跳转到主内容
Sony Vaio Fit SVF15N26CXB Speaker Replacement
你所需要的
  1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 2 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 3 中的图像 1,3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 3 中的图像 2,3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Remove six 5.75mm Phillips #00 screws from the speakers.
  6. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 6 中的图像 1,3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 6 中的图像 2,3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to flip up the black latch on the four ZIF connectors.
    • Remove the four ribbon cables from the ZIF connectors.
    • Disconnect the speaker from the board.
  7. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 7 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 7 中的图像 2,2
    • Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
    • Where the wire is stuck under tape, gently pull the tape up until the wire is free.
    • Do not remove the tape.
  8. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
结论
另外一个人完成了本指南。
Althea McDavid
于02/14/18注册
857 声望
创作了6篇指南
团队
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 的会员
USFT-NANCE-S18S2G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 488
