跳转到主内容
Sony Vaio Fit SVF15N26CXB Hard Drive Replacement
你所需要的
  1. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 2 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 3 中的图像 1,3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 3 中的图像 2,3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Remove the four 3.20mm Phillips #00 screws from the hard drive.
  6. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 6 中的图像 1,3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 6 中的图像 2,3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to flip up the black latch on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive.
    • Disconnect the hard drive and remove.
  7. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 7 中的图像 1,2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case.
    • Carefully peel foil tray off of hard drive.
结论
2等其他人完成本指南。
Althea McDavid
于02/14/18注册
857 声望
创作了6篇指南
团队
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 的会员
USFT-NANCE-S18S2G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 1,189
