跳转到主内容
Sony Vaio Fit SVF14A190X Ram Replacement
你所需要的
  1. Sony Vaio Fit SVF14A190X Ram Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 2 中的图像 1,3 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 2 中的图像 2,3 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 3 中的图像 1,3 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 3 中的图像 2,3 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 4 中的图像 1,2 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
  5. Sony Vaio Fit SVF14A190X Ram Replacement, RAM Replacement: 步骤 5 中的图像 1,1
    • The RAM is a small rectangular component located on the opposite side of the lab top from where you pulled out the CD disc drive.
  6. Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 6 中的图像 1,3 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 6 中的图像 2,3 Sony Vaio Fit SVF14A190X Ram Replacement: 步骤 6 中的图像 3,3
    • Push down on the metal prongs encircled to allow the RAM component to spring up diagonally from the lab top.
    • When the RAM is sprung up, pull it out in the same direction it is currently at, to remove it from the lab top.
结论
另外一个人完成了本指南。
Bryan J. Hartman
于02/13/18注册
255 声望
创作了2篇指南
团队
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G3
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 373
