跳转到主内容
Sony Vaio Fit SVF14A190X Fan Replacement
你所需要的
  1. Sony Vaio Fit SVF14A190X Fan Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 2 中的图像 1,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 2 中的图像 2,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 3 中的图像 1,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 3 中的图像 2,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 4 中的图像 1,2 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
  5. Sony Vaio Fit SVF14A190X Fan Replacement, Fan Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips head screw driver to remove the two 5 mm screws on the fan.
    • Loosen the four screws with the Phillips head screw driver on the copper cooling component. These screws will not come all of the way out.
  6. Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 6 中的图像 1,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 6 中的图像 2,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 6 中的图像 3,3
    • Gently grab the base of the fan wire connection.
    • Pull the base of the wire connection from the motherboard to disconnect the wires.
  7. Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 7 中的图像 1,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 7 中的图像 2,3 Sony Vaio Fit SVF14A190X Fan Replacement: 步骤 7 中的图像 3,3
    • Once the prior two steps have been completed, obtain the plastic opening tool.
    • Gently place the plastic opening tool underneath the fan and separate the fan from the device by sliding the tool along the bottom of the fan.
    • Once separated, you can now lift the fan out by hand.
结论
Bryan J. Hartman
于02/13/18注册
255 声望
创作了2篇指南
团队
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G3
4 名成员
创作了11篇指南
一条评论
Nice
This my problem In my PC
abbass aljobara - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 596
