跳转到主内容
Sony Vaio Fit SVF14A190X Battery Replacement
你所需要的
  1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 2 中的图像 1,3 Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 2 中的图像 2,3 Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 3 中的图像 1,3 Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 3 中的图像 2,3 Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 4 中的图像 1,2 Sony Vaio Fit SVF14A190X  Battery Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
结论
另外一个人完成了本指南。
Randal Crosby
于02/13/18注册
187 声望
撰写一个指南
团队
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G3
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,908
