跳转到主内容
Sony Vaio Fit SVF13N1ASNS Display Replacement
你所需要的
  1. Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 2 中的图像 1,2 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 3 中的图像 1,3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 3 中的图像 2,3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 3 中的图像 3,3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF13N1ASNS Display Replacement, Display: 步骤 5 中的图像 1,1
    • Open the laptop and rotate the screen to the back side.
    • Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
  6. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 6 中的图像 1,2 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 6 中的图像 2,2
    • Rotate the screen back and close the laptop.
    • Use a plastic opening tool to carefully pry up the back plastic case.
    • Remove the back plastic case by sliding it down and pulling upwards.
  7. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 7 中的图像 1,2 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 7 中的图像 2,2
    • Remove the thirteen 2.85mm Phillips #00 screws from the screen.
  8. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 8 中的图像 1,3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 8 中的图像 2,3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Pull the display ribbon cable out of the ZIF connector.
  9. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 9 中的图像 1,3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 9 中的图像 2,3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 9 中的图像 3,3
    • Remove the display cable peeling up the tape.
    • The display cable locking mechanism is attached to the tape.
  10. Sony Vaio Fit SVF13N1ASNS Display Replacement: 步骤 10 中的图像 1,1
    • Remove the display.
结论
3等其他人完成本指南。
Althea McDavid
于02/14/18注册
857 声望
创作了6篇指南
团队
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 的会员
USFT-NANCE-S18S2G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 2,499
