跳转到主内容
Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
你所需要的
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 步骤 3 中的图像 1,2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 步骤 3 中的图像 2,2
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 步骤 5 中的图像 1,2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 65
总计 3,967
