跳转到主内容
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
你所需要的
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 步骤 2 中的图像 1,2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 步骤 2 中的图像 2,2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 步骤 3 中的图像 1,1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: 步骤 4 中的图像 1,2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: 步骤 4 中的图像 2,2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 步骤 5 中的图像 1,3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 步骤 5 中的图像 2,3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: 步骤 5 中的图像 3,3
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: 步骤 6 中的图像 1,2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: 步骤 6 中的图像 2,2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
结论
4等其他人完成本指南。
Marii
于01/08/15注册
658 声望
创作了3篇指南
团队
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G19
4 名成员
创作了12篇指南
一条评论
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 4,528
