跳转到主内容
Sony Vaio Fit 13A Back Cover Replacement
你所需要的
  1. Sony Vaio Fit 13A Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Sony Vaio Fit 13A Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Back Cover Replacement: 步骤 2 中的图像 1,2 Sony Vaio Fit 13A Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Back Cover Replacement: 步骤 3 中的图像 1,1
    • Lift off back cover to access inner components of computer.
结论
2等其他人完成本指南。
Alex Prange
于01/08/15注册
527 声望
创作了3篇指南
团队
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G19
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 3,688
