跳转到主内容
Sony Vaio Duo 11 SSD Replacement
你所需要的
  1. Sony Vaio Duo 11 SSD Replacement, SSD: 步骤 1 中的图像 1,1
    • Make a system backup!
  2. Sony Vaio Duo 11 SSD Replacement: 步骤 2 中的图像 1,2 Sony Vaio Duo 11 SSD Replacement: 步骤 2 中的图像 2,2
    • Using a spudger, remove the rubber screw covers.
    • Gently remove the speaker covers.
  3. Sony Vaio Duo 11 SSD Replacement: 步骤 3 中的图像 1,1
    • Use a sharp tool to lift up the laptop's cover
  4. Sony Vaio Duo 11 SSD Replacement: 步骤 4 中的图像 1,1
    • Remove cover
  5. Sony Vaio Duo 11 SSD Replacement: 步骤 5 中的图像 1,1
    • Remove all the screws. (Attention: these screws are different! Save them.)
  6. Sony Vaio Duo 11 SSD Replacement: 步骤 6 中的图像 1,2 Sony Vaio Duo 11 SSD Replacement: 步骤 6 中的图像 2,2
    • Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
    • Remove the screws (circled in red) and remove the battery.
    • When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
  7. Sony Vaio Duo 11 SSD Replacement: 步骤 7 中的图像 1,1
    • Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
  8. Sony Vaio Duo 11 SSD Replacement: 步骤 8 中的图像 1,1
    • Remove these screws to make it easier to remove the SSD.
  9. Sony Vaio Duo 11 SSD Replacement: 步骤 9 中的图像 1,1
    • The remove of the ssd
    • Remove the SSD (gently)
    • Replace the SSD ( it is a mSATA SSD )
    • Put back the screws and close the unit
结论
25等其他人完成本指南。
Zero
于01/08/13注册
856 声望
撰写一个指南
12条评论
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
Anwar - 回复
1TB ssd here I come!!!!
jamice4u - 回复
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
scorpiotide - 回复
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Nathan Price - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 47
总计 41,127
