跳转到主内容
Sony VAIO VPCF 132FX Power Button Replacement
你所需要的
  1. Sony VAIO VPCF 132FX Power Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Power Button Replacement: 步骤 2 中的图像 1,2 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 2 中的图像 2,2
    • Remove the battery
  3. Sony VAIO VPCF 132FX Power Button Replacement, Media Board: 步骤 3 中的图像 1,1
    • Remove the screws and flip it back.
    you need to remove also all the screws from the bottom sides in order to detach the panel!
    Dimitrios Vamv - 回复
  4. Sony VAIO VPCF 132FX Power Button Replacement: 步骤 4 中的图像 1,3 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 4 中的图像 2,3 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 4 中的图像 3,3
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Sony VAIO VPCF 132FX Power Button Replacement: 步骤 5 中的图像 1,1
    • Gently remove the wire of the Power Button.
  6. Sony VAIO VPCF 132FX Power Button Replacement: 步骤 6 中的图像 1,3 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 6 中的图像 2,3 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 6 中的图像 3,3
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
  7. Sony VAIO VPCF 132FX Power Button Replacement, Power Button: 步骤 7 中的图像 1,1
    • Unscrew the Power button.
  8. Sony VAIO VPCF 132FX Power Button Replacement: 步骤 8 中的图像 1,3 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 8 中的图像 2,3 Sony VAIO VPCF 132FX Power Button Replacement: 步骤 8 中的图像 3,3
    • While pulling the button upwards and towards the left (left fingers), push the button inwards (right fingers) at the same time to remove it from its place.
结论
5等其他人完成本指南。
Marjorie
于12/23/13注册
2,273 声望
创作了11篇指南
4条评论
My power on button was broken where the part you depress was detached from the little circuit board because the plastic holder was broke. Rather than buy a new switch assembly I simply lined everything up in the case and use a liberal amount of RTV to hold everything in place. The RTV is flexible enough to allow the plunger to depress the switch on the board and then spring back into place. It has work great this way since I fixed it six months ago.
Mark - 回复
I need a similar or identical part for my Sony VGN-TT130N notebook. Where can I find and purchase this power button assembly?
Gabriel Solnica - 回复
Did you ever find where to buy the part?
Gina Helton -
bonjour mon sony vaio led power vert ne allume pas mais pc marche bien .et ce que je peut active led pawer ?
mostafa chacha - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 45
总计 13,574
