跳转到主内容
Sony VAIO VPCF 132FX Media Board Replacement
你所需要的
  1. Sony VAIO VPCF 132FX Media Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Media Board Replacement: 步骤 2 中的图像 1,2 Sony VAIO VPCF 132FX Media Board Replacement: 步骤 2 中的图像 2,2
    • Remove the battery
  3. Sony VAIO VPCF 132FX Media Board Replacement, Media Board: 步骤 3 中的图像 1,1
    • Remove the screws and flip it back.
    you need to remove also all the screws from the bottom sides in order to detach the panel!
    Dimitrios Vamv - 回复
  4. Sony VAIO VPCF 132FX Media Board Replacement: 步骤 4 中的图像 1,3 Sony VAIO VPCF 132FX Media Board Replacement: 步骤 4 中的图像 2,3 Sony VAIO VPCF 132FX Media Board Replacement: 步骤 4 中的图像 3,3
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Sony VAIO VPCF 132FX Media Board Replacement: 步骤 5 中的图像 1,1
    • Gently remove the wire of the Power Button.
  6. Sony VAIO VPCF 132FX Media Board Replacement: 步骤 6 中的图像 1,3 Sony VAIO VPCF 132FX Media Board Replacement: 步骤 6 中的图像 2,3 Sony VAIO VPCF 132FX Media Board Replacement: 步骤 6 中的图像 3,3
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
结论
另外一个人完成了本指南。
Marjorie
于12/23/13注册
2,273 声望
创作了11篇指南
一条评论
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,379
