跳转到主内容
Sony VAIO VPCEE26FX RAM Replacement
你所需要的
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: 步骤 1 中的图像 1,2 Sony VAIO VPCEE26FX RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: 步骤 2 中的图像 1,2 Sony VAIO VPCEE26FX RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: 步骤 5 中的图像 1,3 Sony VAIO VPCEE26FX RAM Replacement: 步骤 5 中的图像 2,3 Sony VAIO VPCEE26FX RAM Replacement: 步骤 5 中的图像 3,3
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: 步骤 6 中的图像 1,3 Sony VAIO VPCEE26FX RAM Replacement: 步骤 6 中的图像 2,3 Sony VAIO VPCEE26FX RAM Replacement: 步骤 6 中的图像 3,3
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
结论
团队
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S2G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,431
