跳转到主内容
Sony VAIO VPCEE26FX Hard Disk Drive Replacement
你所需要的
  1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: 步骤 1 中的图像 1,2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: 步骤 2 中的图像 1,2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: 步骤 3 中的图像 1,2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: 步骤 3 中的图像 2,2
    • Using a JIS #0 screwdriver, remove the two 4mm screws securing the hard drive cover to the laptop.
    • Lift the hard drive up and out of its place.
    • The drive cover and hard drive are not pictured. They are both missing from this particular device.
结论
团队
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S2G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 1,737
