跳转到主内容
Sony VAIO VPC-EB33FM Keyboard Replacement
你所需要的
  1. Sony VAIO VPC-EB33FM Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 2 中的图像 1,1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 3 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Keyboard Replacement, Hard Drive: 步骤 4 中的图像 1,3 Sony VAIO VPC-EB33FM Keyboard Replacement, Hard Drive: 步骤 4 中的图像 2,3 Sony VAIO VPC-EB33FM Keyboard Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 5 中的图像 1,3 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 5 中的图像 2,3 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 5 中的图像 3,3
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 6 中的图像 1,1
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 7 中的图像 1,1
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 8 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 8 中的图像 2,2
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  9. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 9 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 9 中的图像 2,2
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
  10. Sony VAIO VPC-EB33FM Keyboard Replacement, RAM: 步骤 10 中的图像 1,3 Sony VAIO VPC-EB33FM Keyboard Replacement, RAM: 步骤 10 中的图像 2,3 Sony VAIO VPC-EB33FM Keyboard Replacement, RAM: 步骤 10 中的图像 3,3
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  11. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 11 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 11 中的图像 2,2
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  12. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 12 中的图像 1,3 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 12 中的图像 2,3 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 12 中的图像 3,3
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
  13. Sony VAIO VPC-EB33FM Keyboard Replacement, Keyboard: 步骤 13 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the following screws securing the back cover :
    • Two 3.8-mm screws
    • Two 8.9-mm screws
    • Twelve 7.75-mm screws
  14. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 14 中的图像 1,1
    • Check to make sure all screws have been removed.
    • Using both hands separate the back cover by lifting from the back and working around the perimeter to release tabs.
  15. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 15 中的图像 1,1
    • Uninstalling the keyboard may require a second set of hands.
    • During the removal of the back cover, a screw that attaches the optical drive to the laptop is also taken out. This means the optical drive is ready to be removed.
    • Remove the optical drive by sliding it out.
  16. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 16 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 16 中的图像 2,2
    • Once the optical drive is removed, locate the keyboard ejection button and press down on it until you hear a snap.
    • Once you hear this sound, it means that a section of the keyboard has been ejected.
  17. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 17 中的图像 1,1
    • Turn the laptop onto its frontside and unfold the laptop so the keyboard is fully visible.
    • Locate the area where the section of the keyboard was ejected.
  18. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 18 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 18 中的图像 2,2
    • Start to pry out the keyboard with your hands.
    • Be careful not to break any of the hooks that attach the keyboard to the laptop.
    • If it seems difficult to remove the keyboard with your hands, then use a plastic opening tool.
  19. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 19 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 19 中的图像 2,2
    • Remain cautious to not break the hooks.
    • Continue all the way around the keyboard until you can detach it from the laptop.
  20. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 20 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 20 中的图像 2,2
    • Do not immediately pull the keyboard away from the laptop. There is still an attachment between the keyboard and laptop.
    • Turn the keyboard on its face and locate the green tape and the ribbon attachment.
    • Using the metal tweezer, remove only the green sticker.
    • Place the sticker at any location as long as you remember to use it for installing the keyboard.
  21. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 21 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 21 中的图像 2,2
    • Locate the black retaining arms.
    • Using the plastic opening tool, pull the retaining arms out.
    • The retaining arms will not come off completely.
  22. Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 22 中的图像 1,2 Sony VAIO VPC-EB33FM Keyboard Replacement: 步骤 22 中的图像 2,2
    • It is safe to touch the ribbon attachment.
    • Lift the retaining arms with the plastic opening tool at an angle so that the ribbon attachment can be pulled out.
结论
10等其他人完成本指南。
Kevin
于01/11/13注册
519 声望
创作了3篇指南
团队
Cal Poly, Team 18-39, Regan Winter 2013 Cal Poly, Team 18-39, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G39
5 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 24
总计 19,611
