当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
You may need to use your other hand to safely remove the panel.
You can also use a spudger for this step.
Grab the tab between your thumb and index finger.
Hold the hard drive securely in a horizontal position using your other hand.
Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
If you need to remove the bracket from the hard drive, follow the next few steps:
Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
Lift the bracket off the hard drive.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
