跳转到主内容
Sony VAIO VGN-FW 590 Keyboard Key Replacement
你所需要的
  1. Sony VAIO VGN-FW 590 Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 1,1
    • Open your computer.
    • Make sure the computer is turned off.
  2. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 步骤 2 中的图像 1,1
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 步骤 3 中的图像 1,2 Sony VAIO VGN-FW 590 Keyboard Key Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  4. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 步骤 4 中的图像 1,1
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  5. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 步骤 5 中的图像 1,1
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
结论
Congratulations! You have successfully replaced a key on your keyboard.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 1,492
