跳转到主内容
Sony VAIO VGN-FW 590 Battery Replacement
你所需要的
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sony VAIO VGN-FW 590 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: 步骤 2 中的图像 1,2 Sony VAIO VGN-FW 590 Battery Replacement: 步骤 2 中的图像 2,2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: 步骤 3 中的图像 1,2 Sony VAIO VGN-FW 590 Battery Replacement: 步骤 3 中的图像 2,2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
结论
Morton Wakeland
于10/30/17注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 811
