跳转到主内容
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
你所需要的
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: 步骤 1 中的图像 1,1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
    If a hard drive is installed it has to be removed to complete the next step. There are also two screws (one on each side) of the battery connector that have to be removed.
    Daniel - 回复
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 3 中的图像 1,1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 4 中的图像 1,1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 5 中的图像 1,2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 5 中的图像 2,2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
结论
2等其他人完成本指南。
2条评论
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - 回复
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 2,427
