跳转到主内容
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
你所需要的
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: 步骤 1 中的图像 1,1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 2 中的图像 1,1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 3 中的图像 1,1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 4 中的图像 1,1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 5 中的图像 1,2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 步骤 5 中的图像 2,2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
结论
2等其他人完成本指南。
2条评论
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - 回复
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 2,489
