跳转到主内容
Sony VAIO PCG-F360 Speaker Replacement
你所需要的
  1. Sony VAIO PCG-F360 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Replacement: 步骤 2 中的图像 1,1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Replacement: 步骤 4 中的图像 1,1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: 步骤 5 中的图像 1,3 Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: 步骤 5 中的图像 2,3 Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: 步骤 5 中的图像 3,3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Replacement: 步骤 6 中的图像 1,3 Sony VAIO PCG-F360 Speaker Replacement: 步骤 6 中的图像 2,3 Sony VAIO PCG-F360 Speaker Replacement: 步骤 6 中的图像 3,3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony VAIO PCG-F360 Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 Sony VAIO PCG-F360 Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • The two speakers are located on the ends of the panel.
    • There are two screws holding each speaker. Remove them using a #00 Philips head screw driver.
  8. Sony VAIO PCG-F360 Speaker Replacement: 步骤 8 中的图像 1,1
    • Carefully flip the speaker over and replace or clean the needed parts.
结论
Hannah Millea
于03/11/14注册
401 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014 的会员
UMASSD-CALAWAY-S14S3G5
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 204
