跳转到主内容
加入维修社区 - 创建账户
Sony VAIO PCG-F360 Fan Replacement
你所需要的
    1. Sony VAIO PCG-F360 Fan Replacement, Battery: 步骤 1 中的图像 1,1
      • Position the laptop screen-side down as shown.
      • In this position the battery housing will be located on the right hand side.
      询问修复机器人
      添加评论
    2. Sony VAIO PCG-F360 Fan Replacement: 步骤 2 中的图像 1,1
      • Lift the panel up and then out to gain access to the battery.
      询问修复机器人
      添加评论
    3. Sony VAIO PCG-F360 Fan Replacement: 步骤 3 中的图像 1,1
      • Use the indentations to pull the old battery out.
      询问修复机器人
      添加评论
    4. Sony VAIO PCG-F360 Fan Replacement: 步骤 4 中的图像 1,1
      • The battery is now removed and it is safe to move on to uninstalling other components.
      询问修复机器人
      添加评论
    1. Sony VAIO PCG-F360 Fan Replacement, Keyboard: 步骤 5 中的图像 1,3 Sony VAIO PCG-F360 Fan Replacement, Keyboard: 步骤 5 中的图像 2,3 Sony VAIO PCG-F360 Fan Replacement, Keyboard: 步骤 5 中的图像 3,3
      • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
      • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
      • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
      询问修复机器人
      添加评论
    2. Sony VAIO PCG-F360 Fan Replacement: 步骤 6 中的图像 1,3 Sony VAIO PCG-F360 Fan Replacement: 步骤 6 中的图像 2,3 Sony VAIO PCG-F360 Fan Replacement: 步骤 6 中的图像 3,3
      • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
      • Remove the ribbon by gently pulling on it, there should be little or no resistance.
      • Now the speaker panel can be set aside.
      询问修复机器人
      添加评论
    3. Sony VAIO PCG-F360 Fan Replacement: 步骤 7 中的图像 1,2 Sony VAIO PCG-F360 Fan Replacement: 步骤 7 中的图像 2,2
      • Remove the metal screw that will be located at the red circle.
      • Pull on the green strip, and the keyboard should come free easily.
      询问修复机器人
      添加评论
    1. Sony VAIO PCG-F360 Fan Replacement, Display: 步骤 8 中的图像 1,3 Sony VAIO PCG-F360 Fan Replacement, Display: 步骤 8 中的图像 2,3 Sony VAIO PCG-F360 Fan Replacement, Display: 步骤 8 中的图像 3,3
      • Remove the six screws along the hinges (three on either side).
      • Twist and pry at the hinge covers with a spudger until they pop up and remove them.
      询问修复机器人
      添加评论
    2. Sony VAIO PCG-F360 Fan Replacement: 步骤 9 中的图像 1,2 Sony VAIO PCG-F360 Fan Replacement: 步骤 9 中的图像 2,2
      • With the computer facing you open its lid carefully, so that the computer looks like this.
      • Because you are removing screws from the hinge, be especially careful to not damage the hinge or the screen when opening the laptop. Be slow about opening it and make sure that the display doesn't fall out.
      • Remove the two screws holding the ribbon cable in place (pictured here without screws).
      询问修复机器人
      添加评论
    3. Sony VAIO PCG-F360 Fan Replacement: 步骤 10 中的图像 1,3 Sony VAIO PCG-F360 Fan Replacement: 步骤 10 中的图像 2,3 Sony VAIO PCG-F360 Fan Replacement: 步骤 10 中的图像 3,3
      • Remove the black screw with your Phillips screwdriver.
      • Remove the screw in the upper right corner while holding the bottom right side of the computer display.
      • Carefully pry the ribbon from its connector and lift it up.
      询问修复机器人
      添加评论
    4. Sony VAIO PCG-F360 Fan Replacement: 步骤 11 中的图像 1,1
      • Remove the screw in the upper left corner that connects the display frame to the laptop.
      询问修复机器人
      添加评论
    5. Sony VAIO PCG-F360 Fan Replacement: 步骤 12 中的图像 1,3 Sony VAIO PCG-F360 Fan Replacement: 步骤 12 中的图像 2,3 Sony VAIO PCG-F360 Fan Replacement: 步骤 12 中的图像 3,3
      • Tilt the display backwards. Grip the display from its base to reduce torque.
      • Use a spudger to pry the upper part of the back panel by pushing in the tabs located along its length.
      • This step is particularly tricky during reassembly, as the plastic must be perfectly aligned or it will not snap in. If it does not snap in correctly, the screen won't fit properly.
      • Carefully lift the display free of the case.
      询问修复机器人
      添加评论
    1. Sony VAIO PCG-F360 Fan Replacement, Fan: 步骤 13 中的图像 1,1
      • Remove the two silver screws with a #00 Philips head screw driver.
      询问修复机器人
      添加评论
    2. Sony VAIO PCG-F360 Fan Replacement: 步骤 14 中的图像 1,1
      • Remove the three black screws with the #00 Philips head screw driver.
      询问修复机器人
      添加评论
    3. Sony VAIO PCG-F360 Fan Replacement: 步骤 15 中的图像 1,1
      • Carefully pull out the fan.
      • You can now clean or replace the fan.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Hannah Millea
于03/11/14注册
401 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014 的会员
UMASSD-CALAWAY-S14S3G5
2 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 37
总计 753
