简介
How to replace the thermal paste into your laptop.
你所需要的
Turn the laptop upside down so that the top is sitting on a flat surface.
If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
Remove the two 4mm Phillips screws in the center of the computer located on each side of the copper electrical strip.
即将完成!
结论
