简介
This repair guide shows how to replace your hard drive.
你所需要的
Turn the laptop upside down so that the top is sitting on a flat surface.
If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
Remove the two 4mm Phillips screws in the center of the computer located on each side of the copper electrical strip.
4等其他人完成本指南。
2条评论
Complete Life Saver Thank you Very much for taking the time to Make an Easily Fallowed guide for this laptop. very very much Appreciated
colbailey1 - 回复
