简介
This repair guide illustrates how to replace the Floppy Disk Drive.
工具
无需工具。
配件
无需配件。
  1. Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    • Turn the laptop upside down
    • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  4. With the laptop facing you, turn the laptop upside down.
    • With the laptop facing you, turn the laptop upside down.
  5. Locate the release switch in the center of the laptop, shown here. Slide the switch, and hold in place.  The floppy disk drive is now free and should easily slide out. Slide the switch, and hold in place.  The floppy disk drive is now free and should easily slide out.
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  6. To replace, insert the new floppy disk drive with the wording facing down.
    • To replace, insert the new floppy disk drive with the wording facing down.
结论
Sara Lillard
于2011年04月11日注册
117 信誉积分
创作了8篇指南
团队
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G36
4 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 1,635
