跳转到主内容
Sony VAIO PCG-933A DVD Drive Replacement
你所需要的
  1. Sony VAIO PCG-933A DVD Drive Replacement, Battery: 步骤 1 中的图像 1,2 Sony VAIO PCG-933A DVD Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A DVD Drive Replacement: 步骤 2 中的图像 1,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 2 中的图像 2,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 2 中的图像 3,3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A DVD Drive Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A DVD Drive Replacement: 步骤 4 中的图像 1,2 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A DVD Drive Replacement: 步骤 6 中的图像 1,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 6 中的图像 2,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 6 中的图像 3,3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A DVD Drive Replacement: 步骤 7 中的图像 1,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 7 中的图像 2,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 7 中的图像 3,3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
  8. Sony VAIO PCG-933A DVD Drive Replacement, DVD Drive: 步骤 8 中的图像 1,2 Sony VAIO PCG-933A DVD Drive Replacement, DVD Drive: 步骤 8 中的图像 2,2
    • Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive.
    • Carefully remove the copper wire strip.
  9. Sony VAIO PCG-933A DVD Drive Replacement: 步骤 9 中的图像 1,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 9 中的图像 2,3 Sony VAIO PCG-933A DVD Drive Replacement: 步骤 9 中的图像 3,3
    • Slide the DVD drive out.
结论
Sara Lillard
于04/11/11注册
165 声望
创作了8篇指南
团队
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G36
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,711
