跳转到主内容
Sony VAIO VPCEC1M1E Keyboard Replacement
你所需要的
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: 步骤 3 中的图像 1,1
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: 步骤 4 中的图像 1,3 Sony VAIO VPCEC1M1E Keyboard Replacement: 步骤 4 中的图像 2,3 Sony VAIO VPCEC1M1E Keyboard Replacement: 步骤 4 中的图像 3,3
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
终点
7等其他人完成本指南。
Stephan
于08/20/11注册
199 声望
撰写一个指南
3条评论
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - 回复
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - 回复
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 22,980
