跳转到主内容
Sony UBP-UX80 Wi-Fi Card Replacement
你所需要的
  1. Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: 步骤 1 中的图像 1,3 Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: 步骤 1 中的图像 2,3 Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 4 中的图像 1,3 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 4 中的图像 2,3 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 4 中的图像 3,3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: 步骤 5 中的图像 1,3 Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: 步骤 5 中的图像 2,3 Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: 步骤 5 中的图像 3,3
    • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
    • Pull directly up on the ribbon cable to disconnect it from the motherboard
    • Gently pull the cable back away from the motherboard pulling the tape off with it
  6. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
  7. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 7 中的图像 1,2 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 7 中的图像 2,2
    • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
    • Unscrew the three 10.5 mm long ph #2 screws on the top.
    • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
  8. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 8 中的图像 1,2 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
  9. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 9 中的图像 1,3 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 9 中的图像 2,3 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 9 中的图像 3,3
    • Lift tab on the left side of the device
    • Work your way right, lifting the next tabs. One on the bottom and one the Top
    • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
  10. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 10 中的图像 1,1
    • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
  11. Sony UBP-UX80 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 11 中的图像 1,2 Sony UBP-UX80 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 11 中的图像 2,2
    • Disconnect the power connection by pulling it straight back and out of the card.
  12. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 12 中的图像 1,2 Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 12 中的图像 2,2
    • Remove the gold-colored connection, remove the tape, and pull it off using the wire. Be gentle because the wire is very small as is the connection.
  13. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 13 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two 4.6 mm screws that secure the card.
  14. Sony UBP-UX80 Wi-Fi Card Replacement: 步骤 14 中的图像 1,1
    • Lift up slightly on the back of the card, and pull out (toward the back of the chassis).
结论
Nate Picard
于03/13/23注册
349 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-5, Petersen Spring 2023 UMass Dartmouth, Team 2-5, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S2G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 67
