跳转到主内容
Sony UBP-UX80 Motherboard Replacement
你所需要的
  1. Sony UBP-UX80 Motherboard Replacement, Top Cover: 步骤 1 中的图像 1,3 Sony UBP-UX80 Motherboard Replacement, Top Cover: 步骤 1 中的图像 2,3 Sony UBP-UX80 Motherboard Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Motherboard Replacement: 步骤 2 中的图像 1,3 Sony UBP-UX80 Motherboard Replacement: 步骤 2 中的图像 2,3 Sony UBP-UX80 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Motherboard Replacement: 步骤 3 中的图像 1,2 Sony UBP-UX80 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Motherboard Replacement: 步骤 4 中的图像 1,3 Sony UBP-UX80 Motherboard Replacement: 步骤 4 中的图像 2,3 Sony UBP-UX80 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the four ribbon connections running to the motherboard:
    • Remove the three ribbon cables from the disk drive by pulling straight up.
    • Remove one ribbon cable from the front panel by pulling straight up.
  6. Sony UBP-UX80 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the two power connections from the power board.
    • Disconnect the power connection from the front panel.
    • Do not pull on the wires
  7. Sony UBP-UX80 Motherboard Replacement: 步骤 7 中的图像 1,3 Sony UBP-UX80 Motherboard Replacement: 步骤 7 中的图像 2,3 Sony UBP-UX80 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the seven 10.5 mm screws that secure the motherboard to the case.
    • Remove the three 10.5 mm silver screws from the back of the case.
    • Remove the two 7 mm black screws from the back of the case.
  8. Sony UBP-UX80 Motherboard Replacement: 步骤 8 中的图像 1,2 Sony UBP-UX80 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the front of the motherboard using the heat sink, slide forward and out of the case.
结论
Kenny Young
于03/13/23注册
413 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-5, Petersen Spring 2023 UMass Dartmouth, Team 2-5, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S2G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 115
