跳转到主内容
Sony Tablet S Rear Camera Replacement
你所需要的
  1. Sony Tablet S Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,2 Sony Tablet S Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Rear Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Rear Camera Replacement: 步骤 3 中的图像 1,2 Sony Tablet S Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Rear Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
    • Use caution when removing the cable, as the socket is very fragile.
  5. Sony Tablet S Rear Camera Replacement: 步骤 5 中的图像 1,2 Sony Tablet S Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Use a finger or a spudger to pull on camera housing.
  6. Sony Tablet S Rear Camera Replacement: 步骤 6 中的图像 1,1
    • Remove the assembly from the plastic shielding.
结论
Austin Mann
于09/28/16注册
287 声望
创作了5篇指南
团队
USF Tampa, Team 3-5, Passmore Fall 2016 USF Tampa, Team 3-5, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S3G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 448
