跳转到主内容
Sony TCM-919 Cassette-Corder Operating Buttons Replacement
你所需要的
  1. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Back Cover Screw Removal: 步骤 2 中的图像 1,1
    • Remove the 5 5.95mm screws as indicated in the picture with the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Locate Buttons: 步骤 3 中的图像 1,1
    • Look to the back of the top cover and locate the broken button(s).
  4. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: 步骤 4 中的图像 1,2 Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: 步骤 4 中的图像 2,2
    • Use a splunger tool to undo the two clips that belong to any broken buttons.
    • Turn the device over and using your finger, push out the loose button.
结论
Marygayle Martin
于10/23/14注册
506 声望
创作了5篇指南
团队
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 816
