跳转到主内容
Sony TCM-919 Cassette-Corder Motherboard Replacement
你所需要的
  1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Motherboard Replacement, Back Cover Screw Removal: 步骤 2 中的图像 1,1
    • Remove the 5 5.95mm screws as indicated in the picture using the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: 步骤 3 中的图像 1,2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: 步骤 3 中的图像 2,2
    • Locate the 3-digit tape counter and gently push the tabs apart releasing the counter.
    • Pull the 3-digit tape counter out.
    • Remove the rubber band attaching the 3-digit tape counter to the cassette head.
  4. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: 步骤 4 中的图像 1,2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: 步骤 4 中的图像 2,2
    • Remove the screws as indicated in the picture using the Phillips Head screwdriver.
    • Pull the loosened motor out of the device, and set the motor aside.
  5. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: 步骤 5 中的图像 1,3 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: 步骤 5 中的图像 2,3 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: 步骤 5 中的图像 3,3
    • Removes the 3, 5.95mm screws using the Phillips Head screwdriver as indicated by picture 1.
    • Push firmly on the tabs and lift the tape deck out.
    • Set the tape deck aside.
  6. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motherboard Screws: 步骤 6 中的图像 1,1
    • Remove the 2 5.95mm screws as indicated by the picture using the Phillips Head screwdriver.
  7. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Epoxy: 步骤 7 中的图像 1,1
    • Remove the epoxy completely from the motherboard so that the wires underneath the epoxy can move freely.
  8. Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: 步骤 8 中的图像 1,2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: 步骤 8 中的图像 2,2
    • Remove the motherboard from case.
    • Flip the motherboard around so that the metallic green side is facing you.
    • Desolder the points indicated in picture 2. This should free the wires connected to the motherboard.
    • Remove the motherboard by pulling it out of the device cavity.
结论
Marygayle Martin
于10/23/14注册
506 声望
创作了5篇指南
团队
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,713
