跳转到主内容
Sony TCM-919 Cassette-Corder Microphone Replacement
你所需要的
  1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove battery Cover: 步骤 1 中的图像 1,1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Back Casing: 步骤 2 中的图像 1,1
    • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
  3. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: 步骤 3 中的图像 1,2 Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: 步骤 3 中的图像 2,2
    • Look to the back of the top cover.
    • Desolder the two wires connected to the mircophone using the soldering station.
  4. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: 步骤 4 中的图像 1,2 Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: 步骤 4 中的图像 2,2
    • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
    • Remove the microphone by pulling up.
结论
Marygayle Martin
于10/23/14注册
506 声望
创作了5篇指南
团队
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 503
