跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sony Stereo Cassette-Corder CFS-930,请使用我们的维修手册
  1. Sony Stereo Cassette-Corder CFS-930 Teardown, Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 1 中的图像 1,1
    • The slightly weatherproof shell and gloved buttons make this great for the beach or the river.
  2. Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 2 中的图像 1,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 2 中的图像 2,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 2 中的图像 3,3
    • Start with Removing the Antenna by unscrewing the single screw. Then Unscrew the Seven Screws on the Back of the Radio as indicated in the Photo. Then remove the handle by simply unscrewing the knob in the middle.
  3. Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 3 中的图像 1,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 3 中的图像 2,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 3 中的图像 3,3
    • Remove the two screws located under the Stereo Handle. Now, Wedge open the front of the box. The speaker wires will still be connected at this point, so don't pull too hard
  4. Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 4 中的图像 1,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 4 中的图像 2,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 4 中的图像 3,3
    • Unscrew the Single screw under the tape mechanism. Gently pop out the Radio tuner indicator lever and put to side- Do not attempt to remove this piece , it is soldered to the front face leds
  5. Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 5 中的图像 1,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 5 中的图像 2,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 5 中的图像 3,3
    • Now to remove the tape mechanism. The buttons are gloved so your gonna have to wedge them out of their sleeves. Then when removed from rubbers. Unattach the three (circled in yellow) flat cables connected to the board.
  6. Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 6 中的图像 1,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 6 中的图像 2,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 6 中的图像 3,3
    • Disconnect the Flat Cable that stems to the Speakers. Remove The Screw on the right, then the Middle, then the one on the left of the MainBoard. The left one has a little supporting metal piece, remove that as well.
  7. Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 7 中的图像 1,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 7 中的图像 2,3 Sony Stereo Cassette-Corder CFS-930 Teardown: 步骤 7 中的图像 3,3
    • Undo the retaining clip from the Board. Make sure when Wedging upward the Radio receiver wheel is in good shape on the right of the board- and remember to realign during reassembly. Lean board upward. This is as far as i am going to go with this project because the wires below the board are soldered. Fun Fun Bladow! - Sony Stereo-Corder in a organized pile of heap.
JaosnT
于10/12/09注册
414 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 11,819
