跳转到主内容
Sony Smart Watch SW2 Battery Replacement
你所需要的
  1. Sony Smart Watch SW2 Battery Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Battery Replacement: 步骤 4 中的图像 1,1
    • Set aside the detached LCD screen to access the battery.
    How can i find New sw2 screen
    Eren Can Gelen - 回复
    where can i find this lcd where can i find this lcd display
    Sherali Mahmudov - 回复
    where can i buy this lcd give me a link thank you in advance
    Jerry Geolin - 回复
  5. Sony Smart Watch SW2 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Lift one side of the battery up carefully. There is a thin black circuit adhered to the back of the battery that connects to the motherboard and the charger.
    • The connection is already broken in this image and you will not be able to lift the battery this high.
  6. Sony Smart Watch SW2 Battery Replacement: 步骤 6 中的图像 1,1
    • Push the black piece down while very carefully pulling the battery off. Work your way around without lifting the black piece up too much.
  7. Sony Smart Watch SW2 Battery Replacement: 步骤 7 中的图像 1,1
    • Once the battery is free from the frame adhesive, desolder the black and red battery wires.
    • Remove the battery.
    I think it’s better to memorize or write down the positive and negative sides of the battery when soldering it back.
    Mohammed Alshamrani - 回复
结论
To reassemble your device, follow these instructions in reverse order after the battery is replaced.
2等其他人完成本指南。
Vincent Shiue
于01/22/18注册
256 声望
创作了2篇指南
团队
IUPUI, Team S1-G5, Freund Spring 2018 IUPUI, Team S1-G5, Freund Spring 2018 的会员
IUPUI-FREUND-S18S1G5
3 名成员
创作了2篇指南
2条评论
HI
please from where can i get the battery i want new one you know any website sell this battery
thanks
hossamman2014 - 回复
I think AliExpress has some compatible batteries. I may order one too.
S. Pamnco -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 4,862
