跳转到主内容
Sony SRS-XE200 Microphone Replacement
你所需要的
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: 步骤 1 中的图像 1,2 Sony SRS-XE200 Microphone Replacement, Speaker Assembly: 步骤 1 中的图像 2,2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Microphone Replacement: 步骤 2 中的图像 1,1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Microphone Replacement: 步骤 3 中的图像 1,2 Sony SRS-XE200 Microphone Replacement: 步骤 3 中的图像 2,2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Microphone Replacement: 步骤 4 中的图像 1,2 Sony SRS-XE200 Microphone Replacement: 步骤 4 中的图像 2,2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Microphone Replacement, Battery: 步骤 5 中的图像 1,3 Sony SRS-XE200 Microphone Replacement, Battery: 步骤 5 中的图像 2,3 Sony SRS-XE200 Microphone Replacement, Battery: 步骤 5 中的图像 3,3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Microphone Replacement: 步骤 6 中的图像 1,3 Sony SRS-XE200 Microphone Replacement: 步骤 6 中的图像 2,3 Sony SRS-XE200 Microphone Replacement: 步骤 6 中的图像 3,3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: 步骤 7 中的图像 1,2 Sony SRS-XE200 Microphone Replacement, Charging Port: 步骤 7 中的图像 2,2
    • Remove the charging port.
  8. Sony SRS-XE200 Microphone Replacement, Microphone: 步骤 8 中的图像 1,3 Sony SRS-XE200 Microphone Replacement, Microphone: 步骤 8 中的图像 2,3 Sony SRS-XE200 Microphone Replacement, Microphone: 步骤 8 中的图像 3,3
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
  9. Sony SRS-XE200 Microphone Replacement: 步骤 9 中的图像 1,1
  10. Sony SRS-XE200 Microphone Replacement: 步骤 10 中的图像 1,2 Sony SRS-XE200 Microphone Replacement: 步骤 10 中的图像 2,2
  11. Sony SRS-XE200 Microphone Replacement: 步骤 11 中的图像 1,3 Sony SRS-XE200 Microphone Replacement: 步骤 11 中的图像 2,3 Sony SRS-XE200 Microphone Replacement: 步骤 11 中的图像 3,3
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 197
