简介
The Sony SRS-XE200 is a compact and portable Bluetooth speaker that delivers impressive audio performance. However, like the battery in any battery-powered device, the one in the Sony SRS-XE200 may eventually need to be replaced due to wear and tear or diminished performance. If you're experiencing issues with the battery life or charging of your Sony SRS-XE200, it may be time for a battery replacement.
你所需要的
Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
Separate the motherboard from the case.
另外一个人完成了本指南。
