跳转到主内容
Sony SRS-XB40 Auxiliary Input Replacement
你所需要的
  1. Sony SRS-XB40 Auxiliary Input  Replacement, Speaker Assembly Replacement: 步骤 1 中的图像 1,1
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
  2. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 2 中的图像 1,1
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
  3. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 3 中的图像 1,1
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
  4. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 4 中的图像 1,1
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
  5. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 5 中的图像 1,2 Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 5 中的图像 2,2
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
  6. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 6 中的图像 1,1
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
  7. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 7 中的图像 1,3 Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 7 中的图像 2,3 Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 7 中的图像 3,3
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
  8. Sony SRS-XB40 Auxiliary Input  Replacement, Auxiliary Input: 步骤 8 中的图像 1,2 Sony SRS-XB40 Auxiliary Input  Replacement, Auxiliary Input: 步骤 8 中的图像 2,2
    • Unscrew the PH 1 (10 mm) screws from the black outer casing of the auxiliary port.
  9. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 9 中的图像 1,2 Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 9 中的图像 2,2
    • After removing the screws, pry the black cover from the base of the speaker on both sides using a metal spudger.
  10. Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 10 中的图像 1,3 Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 10 中的图像 2,3 Sony SRS-XB40 Auxiliary Input  Replacement: 步骤 10 中的图像 3,3
    • Once the black casing has been removed, you can pull the auxiliary port out of the inside of the speaker.
    • The Auxiliary input is attached to the USB port and reset button. One new part will replace all three components of the speaker.
结论
2等其他人完成本指南。
5条评论
Yea but where do I buy the aux input? You say one new part. They don’t offer it on the Sony parts supplier website. https://sony.encompass.com/model/SONSRSX...
Sean Pryor - 回复
Where can i find the part to repair it?
michaelcyrdupuis - 回复
I am trying to find the auxiliary port, I can’t find it anywhere right now.
tesolowski2000 - 回复
Did you find one? If so where please?
kate_eskes -
Where can I source the aux in part? This is the same question as the last 3 comments! Have I missed something?
kate_eskes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 2,201
