简介
This Audio System is the model SRS-XB30. One of the common malfunctions is the charging port. This guide will show you step by step instructions on how to replace the charging port.
你所需要的
Locate the circuit box containing the yellow charging port.
Remove the circuit box from any attachments connecting it to the speaker.
4等其他人完成本指南。
8条评论
Hi where I can find new circuit box?
That’s right , at the very beginning it says that no parts are needed , what about the new charging port where can we get it?
I am incredibly curious, and a little bit excited, to hear what it is that was going through your mind at the start of this in comparison to when you reached the end? The exact moment that the very title of this article says very clearly the word “replacement” and then to see the amazing luck of the mistaken omission which read “No Parts Required” only to then be let down again when you realized that a part was in fact required. After-all it is called “Charging Port Replacement” so I’m sure you probably healed up pretty quick from the heartbreak you suffered.
Very clear instructions, thanks.
Any idea where I can find a new charging port for my speaker? Can’t find anything on the internet..
Thanks by advance
Dries
