跳转到主内容
Sony SRS-XB13 Battery Replacement
你所需要的
  1. Sony SRS-XB13 Battery Replacement, Microphone: 步骤 1 中的图像 1,3 Sony SRS-XB13 Battery Replacement, Microphone: 步骤 1 中的图像 2,3 Sony SRS-XB13 Battery Replacement, Microphone: 步骤 1 中的图像 3,3
    • To get the bottom part of the speaker off, take a long and sturdy screwdriver and put it through the holes at the bottom of the speaker.
    • When you have the screwdriver through the holes, you'll want to push down very firmly. Rotate between the holes and repeat this process until the bottom piece pops off.
    • It can be quite difficult to pry the bottom off due to the adhesive connecting the parts. Prying the bottom off may cause damage to the outside of the speaker.
    • You may find it easier to open the device if you use a heating element (heat gun or hairdryer) around the seam of the device where it is glued shut. Evenly apply heat all around the device, then attempt to pry for this method.
    • Opening the speaker will nullify its waterproof capabilities.
  2. Sony SRS-XB13 Battery Replacement: 步骤 2 中的图像 1,2 Sony SRS-XB13 Battery Replacement: 步骤 2 中的图像 2,2
    • You should see three 11 mm screws once the bottom of the device is off. Use a #1 Phillips screwdriver to remove these screws.
  3. Sony SRS-XB13 Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • To unplug the microphone from the motherboard, use the nylon tipped tweezers to clamp the white block that is attached to the red and white wires.
    • Pull up and away from the motherboard until the block is fully disconnected from the slot.
    • The white block is plugged into the motherboard via a beige-colored slot.
    • Do not tug or pull on the red and black wires when attempting to disconnect the microphone. Doing so can severely damage the wires that power the microphone.
  4. Sony SRS-XB13 Battery Replacement: 步骤 4 中的图像 1,3 Sony SRS-XB13 Battery Replacement: 步骤 4 中的图像 2,3 Sony SRS-XB13 Battery Replacement: 步骤 4 中的图像 3,3
    • Place one end of the ifixit opening tool underneath the white bracket that sits above the motherboard, so that it latches onto the bottom side of the bracket.
    • With the opposite end of the tool, apply a gentle but firm downward motion to slowly pry the bracket from its position.
    • The microphone is embedded within the white bracket, so to replace the microphone, you must replace the bracket.
    • Once enough separation has occurred between the bracket and the motherboard, you can use your fingers to finish fully prying the bracket from its position.
    • The bracket has multiple edges that can be latched onto with the opening tool. It is recommended to use the opening tool in a counterclockwise pattern around the bracket. This helps prevent damaging the bracket, and smoothly releases it from its position.
  5. Sony SRS-XB13 Battery Replacement, Motherboard: 步骤 5 中的图像 1,3 Sony SRS-XB13 Battery Replacement, Motherboard: 步骤 5 中的图像 2,3 Sony SRS-XB13 Battery Replacement, Motherboard: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the precision tweezers set, pinch the tabs on the electric plugins and gently pull outwards to disconnect the wires from the motherboard.
    • Insert a finger under the motherboard and gently lift it out of the casing.
    • Make sure to be gentle when taking the motherboard out, as being too rough can cause damage to it.
  6. Sony SRS-XB13 Battery Replacement, Speaker: 步骤 6 中的图像 1,2 Sony SRS-XB13 Battery Replacement, Speaker: 步骤 6 中的图像 2,2
    • Locate the four 11 mm screws along the base of the white center block.
    • Use the Phillips #1 screwdriver with the 150mm flex extension from the Mako Driver kit to unscrew and remove the screws from their positions.
    • If you have difficulty reaching the screws with the screwdriver and extension, you can use a metal spudger to unscrew them.
    • Using an alternative method to reach the screws in such a tight space is viable, but be wary of damaging the screws in the process.
  7. Sony SRS-XB13 Battery Replacement: 步骤 7 中的图像 1,2 Sony SRS-XB13 Battery Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the blunt tweezers from the precision tweezers set to clamp down on a solid piece of the white center block.
    • With a firm grip, pull upwards with the blunt tweezers until the white center block is released from its position.
    • There are multiple sections of the white center block that can be used to pull it from its position. You may need to work around the block with the tweezers to get it to fully release.
  8. Sony SRS-XB13 Battery Replacement: 步骤 8 中的图像 1,3 Sony SRS-XB13 Battery Replacement: 步骤 8 中的图像 2,3 Sony SRS-XB13 Battery Replacement: 步骤 8 中的图像 3,3
    • Locate the small brackets along the side of the white center block that hold the red, yellow, black, and white wires in place.
    • With your fingers, gently pull the wires away from the center block so that they are no longer held up by the brackets.
    • Flip the white center block over so that the black speaker is facing upwards.
    • Firmly grasp the speaker with your hands and pull it up and away from the center block until it fully disconnects from it.
    • The speaker is attached to the center block via the 4 metal slots along its edges.
  9. Sony SRS-XB13 Battery Replacement, Battery: 步骤 9 中的图像 1,3 Sony SRS-XB13 Battery Replacement, Battery: 步骤 9 中的图像 2,3 Sony SRS-XB13 Battery Replacement, Battery: 步骤 9 中的图像 3,3
    • Follow the red, yellow, and black cables to below the speaker.
    • Using the iFixit spudger, pry the battery from the case.
结论
另外一个人完成了本指南。
一条评论
Thanks to the people who put this article together for the Sony SRS-XB13 blue tooth speaker battery replacement. I have one of these speakers but is still pretty new and the battery replacement is a ways off. It's pretty clear Sony followed Apple small device battery replacement business model and both are PURE BS to begin with. Nothing user friendly about this process but being a power user I can digest it. Both companies deserve a slap upside the head for this type of industrial design on high utilization consumer devices. For the average consumer, this speaker becomes a BIC LIGHTER once the re-chargable battery BITES The Dust.... toss it and they do toss this stuff all too often. Someone get Joe (the Author) a job at SONY and show them how to make it right for the average consumer. Can someone forward this to an Exec at Sony...? That would be really cool and thanks in advance if done..... :)
Jolted Consumer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 73
总计 414
