跳转到主内容
Sony SRS-X5 Bluetooth Replacement
你所需要的
  1. Sony SRS-X5 Bluetooth Replacement, Battery: 步骤 1 中的图像 1,1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Bluetooth Replacement: 步骤 2 中的图像 1,2 Sony SRS-X5 Bluetooth Replacement: 步骤 2 中的图像 2,2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Bluetooth Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Bluetooth Replacement, Speaker: 步骤 4 中的图像 1,1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 Bluetooth Replacement: 步骤 5 中的图像 1,1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Bluetooth Replacement: 步骤 6 中的图像 1,2 Sony SRS-X5 Bluetooth Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Bluetooth Replacement: 步骤 7 中的图像 1,3 Sony SRS-X5 Bluetooth Replacement: 步骤 7 中的图像 2,3 Sony SRS-X5 Bluetooth Replacement: 步骤 7 中的图像 3,3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 Bluetooth Replacement, Bluetooth: 步骤 8 中的图像 1,2 Sony SRS-X5 Bluetooth Replacement, Bluetooth: 步骤 8 中的图像 2,2
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 Bluetooth Replacement: 步骤 9 中的图像 1,1
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 Bluetooth Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard.
结论
2等其他人完成本指南。
一条评论
Muy bueno! Gracias Jeffrey!.
LUIS CARLOS MEJIA DIAZ - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 1,983
