跳转到主内容
简介
On this guide, the aim is to teach how to disassemble the Sony SRS-X3 bluetooth speaker in order to replace the speakers in the unit. This teardown is fairly simple, and only requires two tools. This speaker replacement is being completed because of a humming sound coming from the unit when music is being played.
配件
没有特定配件。
  1. Remove rubber feet on the bottom of the device
    • Remove rubber feet on the bottom of the device
  2. Remove 6 silver philips head screws with PH1 bit
    • Remove 6 silver philips head screws with PH1 bit
    • Remove bottom plastic cover of speaker
  3. Remove 2 phillips head screws holding battery pack with PH1 bit
    • Remove 2 phillips head screws holding battery pack with PH1 bit
    • Remove battery back with spudger
  4. Unscrew 3 phillips head screws using PH1 bit
    • Unscrew 3 phillips head screws using PH1 bit
    • Remove green board. Battery pack and green circuit board should still be connected to the speaker by a ribbon wire. This is normal.
  5. Pop off front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking spudger in crack where grey speaker face meets the outer shell You may really have to pry on this part, it is not easy to remove and will pop out when released
    • Pop off front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking spudger in crack where grey speaker face meets the outer shell
    • You may really have to pry on this part, it is not easy to remove and will pop out when released
  6. Remove 8 black phillips head screws shown with PH1 bit
    • Remove 8 black phillips head screws shown with PH1 bit
  7. Remove front face by prying 2 black tabs shown using spudger This face is glued in and may need some elbow grease to remove. Don't worry about breaking anything, as it is all connected
    • Remove front face by prying 2 black tabs shown using spudger
    • This face is glued in and may need some elbow grease to remove. Don't worry about breaking anything, as it is all connected
  8. Remove speaker wires from each speaker (2 wires per speaker) and take speakers out of device
    • Remove speaker wires from each speaker (2 wires per speaker) and take speakers out of device
    • Speaker wire connectors are made to connect very snug, so they should be hard to remove. Give it a good tug and they should pop off the male end
  9. You can now replace your speakers and reassemble this unit. If replacing the mother board continue with steps 10-14 in the mother board repair guide.
    • You can now replace your speakers and reassemble this unit. If replacing the mother board continue with steps 10-14 in the mother board repair guide.
结论
3等其他人完成本指南。
Andrew Troyer
于2017年01月17日注册
309 信誉积分
创作了2篇指南
4条评论
Where would I get the new speakers from tho? Thanks a lot
Ruben Götz - 回复
Where I can buy one speaker as a spare part?
Karim Karimov - 回复
I would also like to know where I can get a replacement speaker
Aaron Todd - 回复
This SRS X3 cannot be used with the dc in 5v plugged, how can i do to make it work continuously with the charge cable? It have to be hacked? thanks
carlos cesar quan - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 23
总计 1,716
