你所需要的
Unclip the battery pack and replace it with another one.
the flat cable being short might disconnect.
If so reconnect the flat cable then connect the battery
6等其他人完成本指南。
2条评论
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
