跳转到主内容
Sony SRS-X3 Battery Charging Port Replacement
你所需要的
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: 步骤 1 中的图像 1,1
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: 步骤 3 中的图像 1,1
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
    Where do you get the board
    shea mcclean - 回复
  4. Sony SRS-X3 Battery Charging Port Replacement: 步骤 4 中的图像 1,2 Sony SRS-X3 Battery Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
    Donde puedo conseguir una placa de circuitos de mi sony srs x-33?
    cristophero.marte - 回复
    Dimana kita bisa beli
    muhidin radho -
    Jika ada tempat kami membeli bolehkah anda menunjukkan toko dan alamatxa saya ingin mengganti suku cadang modul charger speker sony srs x3 kami
    muhidin radho - 回复
结论
5等其他人完成本指南。
11条评论
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - 回复
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
Hello. If you have some soldering experience, it is more economical to replace just a charging port itself. Just google this exact words Micro USB Charging Port OEM Type for Sony SRS-X3 and you’ll find it. Good luck with your project!
G K - 回复
Hi, I have this same problem, broken USB charging port. The soldering looks very fiddly to me, so I would prefer to buy a complete new replacement board if anyone knows where to source it?
Thanks.
Clive Archer - 回复
Hi Clive, did you find a replacement board? I need to replace mine as well.
Julie Miller -
Seems it's a big secret on where to get the USB circuit board , no one is answering the question
Tracy Evens - 回复
Hi, no I haven’t found a replacement board. I kind of forgot about this (bought a Marshall speaker instead ;-) ), but have just found this speaker at the back of my cupboard and still want to repair it. Has anyone found these small powerboards anywhere?
Clive Archer - 回复
Thanks alot! Worked like a charm, the "belt" came off the circuit but after just pushing it back the boombox works fine.
puistari - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 25
总计 6,657
