跳转到主内容
Sony SRS-X3 Auxiliary Port Replacement
你所需要的
  1. Sony SRS-X3 Auxiliary Port  Replacement, Auxiliary Port Replacement: 步骤 1 中的图像 1,1
    • Remove the 6 philips head screws using the screwdriver and the PH1 bit
  2. Sony SRS-X3 Auxiliary Port  Replacement: 步骤 2 中的图像 1,1
    • Remove 5 philips head speakers holding in the battery and the green circuit board. 2 screws holding in the battery and 3 holding the circuit board.
  3. Sony SRS-X3 Auxiliary Port  Replacement: 步骤 3 中的图像 1,1
    • Pick out the battery pack and the green circuit board so that you can see the ribbon wire and the wire running from the battery pack to the circuit board.
  4. Sony SRS-X3 Auxiliary Port  Replacement: 步骤 4 中的图像 1,2 Sony SRS-X3 Auxiliary Port  Replacement: 步骤 4 中的图像 2,2
    • Remove the ribbon wire and the connector coming from the battery pack to the circuit board.
    • These connectors will not easily pull out, so you might have to give them a tug. They aren't very fragile, so don't worry about shredding them.
    • After this step, simply insert a new circuit board and you're done! Reassemble the speaker and start jamming!
    can you please tell me where I can I get a new circuit board for this speaker from ?
    Donna Carter - 回复
    can you please tell me where I can I get a new circuit board for this speaker from?
    Robert belanger - 回复
结论
2等其他人完成本指南。
5条评论
Where did you buy the circuit board?
David Alvarez - 回复
bad repair doesn't actually show replaceing port just circuit board and no info where to buy one.
munchy 22 - 回复
Hi Andrew,
Can you tell me where I can purchase a replacement circuit board? I’m having trouble finding it online.
Part number is SONY 40BKB537U-CNF2G .
Thanks!
Julie Miller - 回复
Where can I buy the circuit board and if you want me to buy it from you fine but tell us or tell me
Thanks
Jose reyes - 回复
Donde puedo conseguir esas refacines
enriquereynahernandez423 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 1,804
