你所需要的
Get one of your pry tools and pry up the back rubber.
Then peel back the rubber and put it to one side
Get your 00 Phillips bit and unscrew all of the screws.
Then get a spudger and take off the back plastic pannel
Get a plastic spudger and carefully pry the battery out.
Give the power connector a firm tug whilst wiggling the connector back and forth.
Alternatively you could use your tweezers to pry the connector out.
Use a pry tool to remove the top cover like you did in Step 2
Then peel back the rubber and put it to one side.
Como puedo volver a pegar la goma frontal cuando se ha despegado sola y ha pedido el pegante?
Get you screwdriver and unscrew the screws.
Once all of the screws are removed you can then pull out the board.
You can remove the ribbon cable with your fingers or with some tweezers.
Get a metal pry tool and get it between the rubber and the plastic.
Once you have a good piece preyed up you can remove it with your hand.
Get your screwdriver and unscrew all of the screws.
You can the get a pry tool and pry up the plastic panel.
Get your tweezers and pry off the connector being careful not to tear the cable.
You can then get a plastic pry tool and put it in one of the corners of the board to pry it up and out of the casing.
10等其他人完成本指南。
5条评论
Did someone replace the battery?
Dónde puedo conseguir el flexor que conecta las dos lógica
Porque al estraerlo se vencieron
