你所需要的
Start opening the battery panel by removing the two rubber seals.
Under the battery there are two phillips tip screws. Remove them to continue to the motherboard disassembly.
Use a phillips screw driver to remove all the visibel screws. There should be 17 screws.
Use your fingers to remove the back enclosure. Unplug the cabels before removing it completely.
2等其他人完成本指南。
5条评论
Hmm you could try a few things:
- Disconnect and connect the batterie -> Observe the status LED if it charges (change colour or so…)
- Meassure the voltage accross the battery (min 3.0V or more)
- Check the connection between batterie and the PCB
Tahnk you for your answer.
The LED is becomming red as it is charging, and after a few seconds it turns of, like it is charged already. But when the power cord is disconnected, the speaker dies.
I will try to open it and check the connections between batteries and PCB, also measure the voltage of the batteries and keep you posted. Weird is that I bought two sets of batteries and it does the same with each one. Unforntunately, I do not have the old battery anymore, because I have dissasemble it because I tought it is not good anymore, but apparently the batteries work fine.
Thank you again :)
On my SRS-BTX-300 the Audio in function including its button has stopped working. Pressing the volume button disconnects BT connection. I have Reset speakers several times to no avail. Any suggestions will be greatly appreciated
